PROBLEM
Basemaps fail to display when exported to PDF from ArcGIS Pro 2.5
First Published: August 6, 2020
Last Published: August 6, 2020
When exporting a layout to PDF from ArcGIS Pro 2.5, the basemap fails to display.
Image showing a layout PDF without the basemap
Cause
This is a known limitation in ArcGIS Pro 2.5 when exporting layouts with high dots per inch (DPI) or output resolution values to PDF.
Solution or Workaround
Lower the DPI value for exporting to PDF. The DPI value to successfully export the basemap varies, depending on the page size. For example, a basemap is displayed in PDF format with a page size of ANSI E (34" x 44") and a DPI value of 700 or less, but not 800 or more.
Image showing a layout PDF with the basemap.
Alternatively, use a smaller page size for the layout. Typically, the smaller the page size, the higher the DPI can be exported. Other workarounds are to use vector basemaps, or to export to formats other than PDF.
Article ID: 000023776
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
