PROBLEM
In ArcGIS Pro, when the 'Clip to index feature' check box is checked in the Layout Properties window for a map series, the basemap layers outside the clipped area do not display in the map view, even though the layers' check boxes are checked in the Contents pane.
In the Map Properties dialog box, on the Clip Layers tab, the basemap layers are unchecked in the 'Exclude layers from clipping' menu. By design, the menu lists all layers in the current map unchecked, causing layers (not exclusive to basemap layers) outside the clipped area to not display in the map view.
Note: The 'Exclude layers from clipping' menu is only available when 'Clip to index feature' is checked.
The image below shows the basemap outside the clipped area displayed in the map view.
Article ID: 000033384
Get help from ArcGIS experts
Start chatting now
