PROBLEM
Basemap is blurry and distorted after running the XY Table To Point tool in ArcGIS Pro
First Published: May 11, 2021
Last Published: May 11, 2021
In ArcGIS Pro, a point feature class can be added to a map based on the x, y, and z coordinates from a table by running the XY Table To Point tool. However, in some instances, the basemap is blurry and distorted after running the XY Table To Point tool.
The image below shows the map before running the XY Table To Point tool.
The map extent in ArcGIS Pro displaying some countries in Europe before running the XY Table To Point tool.
The image below shows the basemap blurry and distorted after running the XY Table To Point tool.
The map showing the European countries symbolized by the blue tear pin symbol and the map extent blurry and distorted.
Cause
An empty map derives the coordinate system from the first layer added to the map. This results in the map frame's coordinate system changing from the default WGS 1984 Web Mercator (Auxiliary Sphere) to WGS 1984 after running the XY Table To Point tool, causing the basemap to appear distorted and blurry.
Solution or Workaround
To resolve this issue, change the coordinate system of the output layer of the XY Table To Point tool, and change the map's coordinate system.
  1. In ArcGIS Pro, click the Analysis tab, and click Tools.
The Analysis tab with Tools to access the Geoprocessing pane.
  1. In the Geoprocessing pane, type Project in the search bar, and click the Project (Data Management Tools) box.
The Geoprocessing pane with the Project tool and the search bar.
  1. In the Project tool pane, for the Input Dataset or Feature Class section, click the down arrow Click the down icon next to the Input Dataset or Feature Class tab to select the input layer. to select the output layer of the XY Table To Point tool.
  2. For the Output Coordinate System section, click the Select coordinate system Access the Coordinate System window to select the coordinate system for the output by clicking the globe-grid icon. icon.
  3. In the Coordinate System window,
    1. Type WGS 1984 Web Mercator in the search bar.
    2. Expand the Projected Coordinate System header and the World subheader, click WGS 1984 Web Mercator (auxiliary sphere).
    3. Click OK.
The Coordinate System window to select the WGS 1984 Web Mercator (auxiliary sphere) coordinate system.
  1. In the Project tool, click Run.
  2. In the Contents pane, right-click the Map layer, and click Properties.
The Contents pane to access the Properties window of the map layer.
  1. In the Map Properties: Map window, click Coordinate Systems on the sidebar.
  2. To match the map's coordinate system to the output layer of the Project tool, type WGS 1984 Web Mercator in the search bar.
  3. Expand the Projected Coordinate System header and the World subheader, and select WGS 1984 Web Mercator (auxiliary sphere).
  4. Click OK.
The Map Properties window to select WGS 1984 Web Mercator (auxiliary sphere) to ensure the coordinate system of the map is the same as the output layer of the Project tool.
The image below shows the final result with the basemap clear and not distorted.
The final map extent displaying some European countries symbolized by the blue tear pin symbol. The map is not blurry and distorted.
Article ID: 000025236
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
