PROBLEM
Barrier selection is ignored when using the fixed search radius method in IDW
The Barrier selection is ignored when using the fixed search radius method in IDW.
Cause
The IDW method will execute but the barrier will be ignored.
Solution or Workaround
Try to modify the task by selecting the variable search method from the list of choices.
Article ID:000007571
Software:
  • Legacy Products
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
