PROBLEM
AVSQL option is greyed out in the setup program
Unable to install AVSQL because the option is not available in the setup program.
Cause
Open Database Connectivity (ODBC) has not been installed.
Solution or Workaround
Install ODBC prior to the installation of AVSQL. ODBC should come with the drivers that are appropriate for use with these connections.
Article ID:000003704
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
