In ArcGIS Experience Builder, the feature layer visibility on the map can be toggled on and off using the Filter widget, and these filters can be applied automatically when the app is open using the 'Apply this filter automatically' setting. However, when using the Filter widget with the Widget Controller widget, the Filter widget cannot automatically filter features, as shown below.
Cause
The ‘Apply this filter automatically’ setting cannot be toggled because widgets in the Widget Controller do not open automatically when the page loads.
Solution or Workaround
Configure the Behavior setting in the Widget Controller panel
- In ArcGIS Experience Builder, navigate to the Insert widget panel.
- Under Menu and tools, drag and drop the Widget Controller widget onto the canvas.
- On the canvas, drag the Filter widget into the Widget Controller.
- In the Widget Controller panel, on the Content tab, under Behavior, click the Open widgets on loading drop-down arrow and select Filter.
- Click Save to save the experience and click Publish to publish the experience to ArcGIS Online.
- To view the published experience, click More from the toolbar at the top of the builder window and click View published item.
The map below shows all the feature layers automatically filtered when the Filter widget is clicked.
Remove the Filter widget from the Widget Controller
- In ArcGIS Experience Builder, on the canvas, drag the Filter widget out of the Widget Controller.
- In the Filter panel, click the filter to open the Create new filter pane. Under Options, toggle Apply this filter automatically on for all the required feature layers. Refer to ArcGIS Experience Builder: Filter widget for more information.
The map below shows all the feature layers automatically filtered when the Filter widget is reconfigured.
