PROBLEM
Attributes are not inherited using the Split tool in ArcGIS Pro
Last Published: May 6, 2024
In some cases, when dealing with utility data, ArcGIS Pro does not inherit the attributes from the original polygon when using the Split tools.
Cause
This is expected behavior when there are domains on the attribute fields, and the values on split are determined by the split policy on the domain. If the Split Policy is set as Default, the attributes of the two resulting features take on the default value for the attribute of the given feature class or subtype. Whereas, if the Split Policy is set as Duplicate, the attribute of the two resulting features takes on a copy of the original object's attribute value.
Solution or Workaround
To resolve this, change the Split Policy to Duplicate and run the Split tool and see if the attributes are inherited from the original polygon.
Article ID: 000031543
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
