PROBLEM
In ArcGIS Online, attribute edits made in one web map are written to the underlying layer, and the changes are automatically reflected in all other web maps that reference the same layer. This affects the symbology configured from the same attribute field, changing how features are displayed across all maps, including any hosted feature layer views.
Hosted feature layers in ArcGIS Online act as a centralized data source, and all associated web maps reference the same layer rather than storing independent copies. While symbology is configured at the web map level, it depends on the attribute values stored in the layer, and edits to the attributes are reflected in the associated web maps.
and select View Details.
and select Open in Map Viewer.
to open the Styles panel and configure the symbology.The web map now uses the newly added field as the dedicated field for symbology, as shown below.
Article ID: 000040778
Get help from ArcGIS experts
Start chatting now
