PROBLEM
Attempts to find and replace multiple data sources from enterprise geodatabase connections using Python fail
Last Published: July 21, 2020
Attempts to use the findAndReplaceWorkspacePaths() function to update layers between two differently named enterprise geodatabases fail, and the layers are not updated.
Cause
The findAndReplaceWorkspacePaths() function works with a file geodatabase, but is not intended for use to switch between two differently named enterprise geodatabases. This is a known limitation. The script fails because the schema for the layer includes the name of the database, hence failing to connect the layers correctly.
Solution or Workaround
As a workaround, use the lyr.replaceDataSource() function.
  1. Import the ArcPy module.
import arcpy
  1. Specify the desired map paths and enterprise geodatabase connection paths.
Map = r'D:\Sample\Sample1.mxd'
NewMap = r'D:\Sample\Sample2.mxd'
FindDB = r'Database Connections\OriginalDB@sa.sde'
ReplaceDB = r'Database Connections\abc.sa.sde'
mxd = arcpy.mapping.MapDocument(Map)
layerList = arcpy.mapping.ListLayers(mxd)
  1. Create a loop to find all the layers and update the path.
for lyr in arcpy.mapping.ListLayers(mxd):
    ds = lyr.dataSource
    if lyr.supports("DATASOURCE"):
        if FindDB in ds:
            print "Layer: " + lyr.name + " Source: " + lyr.dataSource
            lyr.replaceDataSource(ReplaceDB, "SDE_WORKSPACE", "", False)
  1. Save the new map.
mxd.saveACopy(NewMap)
print lyr.dataSource
The following shows the full script:
import arcpy
Map = r'D:\SharedDrive\PathSwitch.mxd'
NewMap = r'D:\SharedDrive\PathSwitch4.mxd'
    ds = lyr.dataSource
        if FindDB in ds:
Article ID: 000022907
Software:
  • ArcMap
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
