PROBLEM
Attempts to edit a hosted feature layer field in the feature pop-up in ArcGIS Online Map Viewer fail, and the following message is returned:
Error: The value entered is not valid.
In this example, the warning message is returned when attempting to change Fresn to ‘Fresno.’
This is a known limitation. The field value in the pop-up and the attribute table can only be selected from the values available in the drop-down list, and the feature template in ArcGIS Online disables input of new field values to prevent incorrect data capturing. In this example, the drop-down list for the user-created hosted feature layer does not contain the value 'Fresno,' but instead contains the misspelled city name 'Fresn.'
To edit the field or pop-up with the desired value, follow one of the workarounds below.
Change the layer symbology from Unique symbols to Single symbol
If a layer uses unique symbology, a drop-down list is automatically applied, and users can only select from the values available in the list. If there is a misspelled value, perform the following steps to rectify it.
Replace the incorrect feature with a new feature type
Note: Ensure layer editing is enabled. Only administrators or owners can enable editing for members. Refer to ArcGIS Online: Manage hosted feature layers for more information.
The feature template can be modified by adding a new feature type with a new name to replace the original feature name. This option is only available if the layer uses unique symbology. Refer to ArcGIS Online: Style categories for more information on symbology.
The following steps describe how to manage the feature template, and delete the original feature name:
Note: The Edit button is only visible to administrators or owners.
button of the feature, and select Remove from the drop-down list. In this example, Fresn is removed.
Article ID: 000023593
Get help from ArcGIS experts
Start chatting now
