PROBLEM
Attachments display unintended texts in ArcGIS Pro pop-ups
First Published: December 24, 2025
Last Published: December 24, 2025
In ArcGIS Pro, when the Attachments element is added while configuring a pop-up, a default text label is displayed below each attachment. This behavior creates an unintended visual element, which can affect clarity, as shown in the image below.
The image attachment displays unintended text in ArcGIS Pro pop-ups
Cause
This is by design. When the Attachments element is added, attachments are automatically assigned a default title and caption, which results in default text displayed below the attachment.
Solution or Workaround
To solve this issue, rename or remove the default caption in the Attachment Options pane when configuring the pop-up.
  1. In the Contents pane, right-click the feature class.
  2. Select Configure Pop-ups.
  3. In the Configure Pop-ups pane, double-click the Attachments element to edit its properties, or click the Edit pop-up element icon The Edit pop-up element icon.
The Edit pop-up element button in the Configure Pop-ups pane
  1. In the Attachment Options pane, for Caption, rename the attachment caption or remove the default 'Text' caption.
The Attachment Options pane
Optionally, for Title, rename or remove the default 'Attachments' title.
The image below shows the renamed default caption in the attachment in the ArcGIS Pro pop-up.
The renamed default caption in the attachment in the ArcGIS Pro pop-up
Article ID: 000039420
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
