PROBLEM
When running a geoprocessing tool such as the Feature To 3D By Attribute, Feature Class To Feature Class, or Feature To Point tool, the tool completes without any error but attachments from the original feature layer are not carried over to the output layer.
In other instances, such as when the Merge tool is run on a feature layer with attachments, the following warning message is returned, “WARNING 001177: Attachments are not supported in this Geodatabase release.”
Depending on the cause, use one of the following options to resolve the issue.
Use geoprocessing tools that support copying of attachments to output layers
Use a geoprocessing tool that copies attachments from the input features to the output features. Refer to ArcGIS Pro: Usage notes for more information.
Ensure the Maintain Attachments check box is checked
When running a geoprocessing tool on a feature layer that contains attachments, ensure the Maintain Attachments check box is checked. The Maintain Attachments check box can be found under Geodatabase on the Environments tab of the Geoprocessing pane.
Note: The Maintain Attachments check box is only available for geoprocessing tools that support the functionality. However, attachments are automatically copied to the output layer even though the check box is not displayed or unchecked in the geoprocessing environment settings when running the Feature Class To Geodatabase or Copy tool.
Assign the ArcGIS Pro Standard or Advanced license to the member
Administrators or organization members with privileges to manage licenses must assign the ArcGIS Pro Standard or Advanced license to the desired member. Refer to ArcGIS Pro: Assign or unassign an ArcGIS Pro add-on license or extension for more information.
For ArcGIS Pro Single Use or Concurrent Use licenses, contact Esri Customer Service to upgrade the license.
Use the Copy tool to maintain attachments with the ArcGIS Pro Basic license
The Copy tool copies attachments from the input features to the output features regardless of the licensing level and the Maintain Attachments environment setting.
Article ID: 000028027
Get help from ArcGIS experts
Start chatting now
