** Internal Publish Only! This article may contain information that is not intended for external circulation. **
Some ArcWeb Toolbar controls do not respond when using the Tab key. They are:- Find Points of Interest
- Find Route
- Get ReportOther ArcWeb Toolbar controls that give selected response using the Tab key: - Add ArcWeb Services Data
Only tabs through the list of ArcWeb Services.- Find Places and Addresses
Find Place section:
Only tabs from Place Name to Place Type after using the cursor to select Place Name.Find Address section:
Only tabs through the text boxes after putting the cursor in the Country text box.
Cause
This is caused by a limitation within .NET.
Solution or Workaround
Use a mouse to operate the toolbar listed above.
