PROBLEM
ArcView does not display a DWG file
For some DWG files, symbology is missing in the table of contents, and the theme does not appear anywhere when the view is displayed.
Solution or Workaround
Do one of the following:
  • Open the file in AutoCAD and save it as a DXF file type.
  • Open the file in AutoCAD and convert it into a blocked DWG.
    Import the DXF or blocked DWG file into ArcView.
Article ID:000004591
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
