PROBLEM
ArcScene: Warning not returned when setting base surface resolution too high
ArcScene is supposed to return a warning when the resolution of a raster base surface has been set too high relative to the amount of available memory. The missing warning makes exceeding the available memory possible.
Cause
This is a known issue.
Solution or Workaround
No solution at this time.
    Article ID:000004455
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
