PROBLEM
When applying base heights to a shapefile using a multi-band image as the height source, it does not drape on top of the image.
In ArcScene, draped features use the maximum resolution of the elevation raster, but that elevation layer is resampled by default. As a result, a much precise draped feature is displayed but on a coarse base surface, which is the cause of the misalignment.
Warning:
ArcScene may crash when increasing the raster resolution for large rasters.
Article ID:000008809
Get help from ArcGIS experts
Download the Esri Support App
