PROBLEM
ArcScene: fails when exporting to VRML
ArcScene may crash when exporting a scene to VRML if the scene contains a large image displayed in hi-resolution.
Cause
VRML export involving image data requires texture resources and memory. The failure occurs if these resources are nearly exhausted before the export process begins and therefore can't acquire what it needs.
Solution or Workaround
Reduce the value on the 'Quality enhancement' slider on the Rendering tab of the raster image layer's Properties dialog box. This will reduce the scene's consumption of resources before attempting to export to VRML.
Article ID:000004706
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
