PROBLEM
ArcScene: Decreased resolution evident with images draped on surfaces of larger extent
The resolution of images downgrades if they're draped on surfaces of larger extent. The greater the discrepancy, the more adverse the effect.
Cause
This is a known problem.
Solution or Workaround
Clip the surface to have the same extent as the image.
    Article ID:000004318
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
