PROBLEM
ArcScene crashes when adding more than 60 TINs
Modeling surfaces often requires the use of more than one surface for the area of interest. If more than sixty TINs are added to ArcScene, the application fails with the following error:"The instruction 0x0000000 referenced memory at 0x0000000 which could not be read."
Cause
This is a known issue.
Solution or Workaround
  • Recreate larger TINs from the original input data so that there are fewer entries in ArcScene's Table of Contents.
  • Convert the TINs into raster datasets, depending on what the TINs represent.
  • Programmatically convert the TINs into Multipatches for display in ArcScene.
Article ID:000008950
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
