PROBLEM
ArcPress clips at letter size with PCL devices
Printing a map larger than letter size with ArcPress, using the HP PCL3 or HP PCL5 driver, causes the output to clip at letter size.
Cause
By default, the HP PCL3 and HP PCL5 drivers are limited to letter size output.
Solution or Workaround
Follow the steps below.
  1. Load the 'device1.dat' file into a text editor. For example, Microsoft WordPad.
    For ArcInfo ArcPress:
    Code:
    $ARCHOME\etc\device1.dat
    For ArcView ArcPress:
    Code:
    arcpress\etc\device1.dat
  2. In the four lines beginning with 'PCL' change '2340' to '3090' and '3000' to '4800'.
  3. Save and close the 'device1.dat' file.
    This makes the maximum printable area for the PCL devices 11" x 17" / tabloid / B size, the largest setting allowed for these ArcPress devices.
Article ID:000001959
Software:
  • ArcMap 8 x
  • ArcMap 9 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
