PROBLEM
ArcMap's advanced symbology option for transparency by field works only on polygons
Feature transparency can be adjusted based on an attribute field value. The values represent a percent of transparency (1-100).
Cause
This is only available for polygon feature layers symbolized using single symbol and unique values.
Solution or Workaround
Use the Effects toolbar to set layer transparency. This is supported for point, line, and polygon feature layers, as well as for raster layers.
[O-Image] Effects Toolbar
Article ID:000002862
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
