PROBLEM
ArcMap sometimes crashes when adding feature-linked annotation
When adding a feature in ArcMap that has feature-linked annotation, ArcMap sometimes crashes.
Cause
This occurs when you select the option to automatically create annotation with new features and the field from which the annotation is created is blank (null).
Solution or Workaround
Set a default value for the fields:
  1. From ArcCatalog, navigate to the feature class that the annotation is linked to.
  2. Right-click the feature class and select Properties.
  3. Click the Fields tab.
  4. Click the appropriate field name and type a default value in the Field Properties.
Article ID:000002522
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
