PROBLEM
ArcMap Server feature not available in installation
The ArcMap Server feature is not listed in the ArcIMS setup program or in the ArcGIS ArcIMS Add/Remove Programs option after installing.
Cause
Internet Explorer 5.0.1 or higher and MDAC 2.5 are required for ArcIMS ArcMap Server. If your system does not meet these requirements, the ArcMap Server feature will not be available in the installation or Add/Remove dialog box.
If you do not have Microsoft Data Access Components (MDAC) 2.5 or higher, the install will optionally let you install it the first time you install ArcIMS.
To add ArcMap Server after installing ArcIMS, you must manually install MDAC 2.5 or higher and/or Microsoft Internet Explorer 5.0.1 or higher before using Add/Remove to add ArcMap Server.
Solution or Workaround
  1. You must obtain and install Internet Explorer 5.0.1 or higher.
  2. Install MDAC by running the mdac_typ.exe from the \support\MDAC folder on the ArcIMS installation CD.
    You will need to reboot your system after installing MDAC.
  3. Launch the ArcIMS installation or, if using Add/Remove to add ArcMap Server, go to Add/Remove Programs and click ArcGIS ArcIMS to add ArcMap Server. Click Add/Remove. The ArcMap Server, under the Spatial Server feature, will be available to install.
    For more information on how to Add/Remove features, please see the ArcIMS Installation guide at <ArcIMS CD or install directory>\documentation\install.htm.
Article ID:000005812
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
