PROBLEM
ArcMap menus and functions have slow performance after saving or exporting an .mxd file
ArcMap performs extremely slowly after saving or exporting any mxd files. The slow performance can also be triggered after working on an MXD for 1 to 30 minutes.
ArcMap performs at normal speed until the performance issue is triggered. Once it is triggered, the CPU usage may stop around 8 to 20%, even while ArcMap sits idle.
Cause
There is a spyware virus called TSPY_AGENT.DE that is planting .dil and .dat files in the system32 folder.
Solution or Workaround
The solution below may not remove the entire virus, but should restore performance in ArcMap.
Additional solutions can be found on the Trend Micro Web site listed below.
  1. Click Start > Search. Search in the c:\windows folder for *.dil files.
  2. Right-click the .dil file and select Open Containing Folder.
  3. The offending file is highlighted and there isĀ also be a corresponding *.dat file.
  4. Either rename the extensions or delete the files, and restart the machine.
Article ID: 000010589
Software:
  • ArcMap
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
