PROBLEM
Field names are displayed in ArcMap's Select by Attributes dialog box instead of field aliases.
The Select by Attributes dialog box sends queries directly to the database. Using field aliases in these queries will not work because the database has no knowledge of them. Field aliases are tied to layers, and are stored in Map documents (.mxd) and layer files (.lyr).
Use field names when building queries in the Select by Attributes dialog.
Article ID:000002824
Get help from ArcGIS experts
Download the Esri Support App
