PROBLEM
ArcMap crashes when canceling login to secure ArcIMS image service while opening a map
If you save a map that contains a secure ArcIMS image service, and do not save the username and password with the connection, you will be prompted to login when you next open the map. If you click cancel on the login dialog box, ArcMap will crash.
Cause
This is a known issue.
Solution or Workaround
This issue has been addressed in ArcGIS Version 8.1.2.
  1. In ArcGIS 8.1, save the login information with the map, or do not cancel the login dialog box when opening the map.
Article ID:000004315
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
