PROBLEM
ArcMap crashes when adding CAD annotation to the display
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
When Visual Learning System's Feature Analyst 3.3 is installed, ArcMap crashes while adding CAD annotation to the display.
Cause
An application called Feature Analyst 3.3, created by Visual Learning System, was installed.
Solution or Workaround
Turn off the Feature Analyst application before adding the CAD annotation to ArcMap.
Article ID:000006637
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
