PROBLEM
ArcMap closes when using geoprocessing wizard clip, intersect or union
Executing clip, intersect, or union in the Geoprocessing wizard crashes ArcMap.
Cause
The amount of RAM and page file space exceed 2.1 gigabytes.
Solution or Workaround
  1. Have your system administrator identify the current amount of RAM being used on your machine.
  2. Subtract this value from 2.1 gigabytes. The difference is the maximum page file size you should use for all drives.
  3. Have your system administrator reset your page file size to the value calculated in Step 2.
Article ID:000004894
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
