PROBLEM
Upon launching ArcMap, a pop-up appears displaying the message 'Generating ArcID Module' and ArcMap closes unexpectedly.
This issue can occur due to compatibility issues with Visual Basic for Applications (VBA) and ArcMap.
This issue can be resolved by disabling the option to preload VBA. VBA applications can still be run by installing the ArcGIS for Desktop VBA Compatibility program.
However, starting with the ArcGIS Desktop 10.5 release, VBA is no longer supported. It is recommended that existing VBA users continue to use ArcGIS Desktop version 10.2.2 or earlier, or migrate VBA customizations to ArcMap add-ins, ArcPy scripts, or ArcGIS Pro add-ins built with the Pro SDK for .NET.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions. Therefore, use caution and proceed at your own risk.
regedit.exe
Article ID:000020943
Get help from ArcGIS experts
Download the Esri Support App
