PROBLEM
ArcIMS Spatial Server crashes when using the Thai th_TH locale on Solaris
The symptoms of the ArcIMS Spatial Server crash are:1. No VirtualServers are listed in ArcIMS Administrator.
2. There is no aimsserver.exe process running, although there is a monitor process running.
3. You get errors in the AppServer_xxxxx.log if you have debugging set to true. For example:[Fri Mar 15 05:10:17 GMT-07:00 2002] Initializer> <ERROR code="1010">
Process could not connect to AppServer on host: mymachine.esri.com, port: 5353
</ERROR>
Cause
Java is expecting a Thai locale other than th_TH.
Solution or Workaround
Change your locale to th_TH.TIS620. After this change, ArcIMS should work as expected.
Article ID:000005090
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
