PROBLEM
ArcIMS components are grayed out in the Add/Remove Programs utility
After the ArcIMS uninstallation is cancelled, returning to and clicking Add/Remove, all the components are grayed out, even though ArcIMS 3.1 is still listed.
Cause
Some ArcIMS files were deleted and some remained.
Solution or Workaround
Manually remove ArcIMS from the system and remove ArcIMS from the registry.
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/18656' target='_blank'>How To: Manually remove ArcIMS from your registry</a>
Article ID:000003458
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
