PROBLEM
ArcGIS World Geocoding Service does not display in ArcGIS Pro
Last Published: January 23, 2026
ArcGIS World Geocoding Service is not available and does not display in the Locate pane or the Geocode Table pane in ArcGIS Pro.
Cause
This occurs when ArcGIS Pro loses its connection to the ArcGIS World Geocoding Service, causing the Locate tool to fail within the application.
Solution or Workaround
To circumvent the issue, manually add the World Locator to ArcGIS Pro.
  1. In ArcGIS Pro, navigate to the Insert tab. Select Connections > Server > New ArcGIS Server. The Add ArcGIS Server Connection dialog box displays.
  2. Enter the following in the Server URL text box:
https://geocode.arcgis.com/arcgis/rest/services
  1. Click OK. If prompted, sign in with an ArcGIS Online account.
  2. Select the Project tab in the Catalog pane.
  3. Right-click Locators > Add Locator > Servers > services on geocode.arcgis.com.ags > World > OK.
Article ID: 000020635
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
