PROBLEM
Adding the Sidecar block is one way to embed multimedia content in ArcGIS StoryMaps. It creates a smooth transition between maps, images, and other media. In some cases, when opening ArcGIS StoryMaps on iOS devices, the web browser crashes and fails to load the embedded maps in the sidecar blocks.
The sidecar contains too many embedded maps. When the sidecar blocks are loading in the web browser, all the embedded maps in the sidecar are downloaded simultaneously, causing the web browser to crash. The best practice is to embed a maximum of four maps in one sidecar.
Note: The following solution may require the story map to be rebuilt. If necessary, duplicate the story map to avoid deleting important data.
In ArcGIS StoryMaps, divide the sidecars containing five or more embedded maps to four as the maximum number of the embedded maps for a sidecar block.
The following image demonstrates the embedded map loaded successfully on the iOS device.
Article ID: 000024710
Get help from ArcGIS experts
Start chatting now
