PROBLEM
ArcGIS Server records events that occur in ArcGIS Server sites, and any errors associated with those events. Events such as starting and stopping a service, connecting to a machine, and so forth, are saved in server logs generally stored in the following directory:
C:\arcgisserver\logs\<machine name>\server\However, there are instances when the logs accumulate to a large enough volume to affect performance, and it is necessary to free up space on the drive.
This issue occurs when ArcGIS Server is run continuously over a long period of time, causing the accumulation of server logs.
Article ID: 000014361
Get help from ArcGIS experts
Start chatting now
