PROBLEM
ArcGIS Pro legend displays an additional label on exported maps
Last Published: January 31, 2023
In ArcGIS Pro, legends can be added to a map layout. However, there are instances where an additional label is displayed in the legend on the exported map.
The image below shows an additional ‘Layer’ label in the map legend of an exported PDF file.
An additional Layer label in the map legend
Cause
The feature class name is empty. ArcGIS Pro automatically names empty feature classes as ‘Layer[number of the layer]’, for example, ‘Layer2’.
Solution or Workaround
  1. In the Contents pane, right-click the feature class and click Properties.
Navigating to the layer properties from the Contents pane
  1. On the General tab of the Layer Properties window, click the text box under Name and press the Spacebar.
  2. Click OK.
A blank feature class name
  1. Export the map. Refer to ArcGIS Pro: Introduction to export a map or layout for more information.
The image below shows the additional legend label removed.
The additional Layer label removed from the map legend
Article ID: 000029250
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
