PROBLEM
Attempts to log in to Portal for ArcGIS using ArcGIS Pro fails with the repeated prompting of the licensing portal login dialog window.
This issue is caused by an inaccurately defined portal configuration file (.json). This makes Portal for ArcGIS unable to identify the License Manager over the network despite using a valid URL to login.
In some environments, if the hostname in the portal configuration file (created in Step 19 of ArcGIS Help: Configure ArcGIS Pro licenses for your organization) is not defined in a fully qualified domain name (FQDN) recognizable by the license server, Portal for ArcGIS is unable to connect to the license manager to verify licensing.
Note: The value Hostname is typically found twice in the portal configuration .json file: once in the middle, and once at the end.
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
HKEY_CURRENT_USER\Software\ESRI\ArcGIS Online For Pro HKEY_CURRENT_USER\Software\ESRI\ArcGISPro HKEY_CURRENT_USER\Software\ESRI\ArcGISPro1.0 HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISPro
Article ID: 000013083
Get help from ArcGIS experts
Start chatting now
