PROBLEM
ArcGIS Pro crashes when projecting through a Clickshare device
First Published: June 11, 2019
Last Published: August 5, 2025
ArcGIS Pro crashes when projecting through a Clickshare device.
Cause
This crash is not due to a defect in ArcGIS Pro. The crash occurs due to DLL injection by the Clickshare driver. DLL Injection is a way for advanced programs to load their own code into another application’s address space. The crash occurs in DXCap64.dll - the Clickshare capture driver. This is why it is only reproducible when using the Barco Clickshare device.
Solution or Workaround
Esri corresponded with Barco Support and their recommended workaround is to disable DLL injection by setting an environment variable, see the Barco technical article: Can I Turn off DLL injection?
Article ID: 000021161
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
