PROBLEM
In ArcGIS Pro, geoprocessing workflows involving multiple tools can be automated using ModelBuilder and be saved as a model tool in a toolbox. These tools are run as any other geoprocessing tool from the Geoprocessing pane. In some instances, opening a model tool may cause ArcGIS Pro to crash or return the following error message in the Geoprocessing pane:
Error: Tool has failed to open
Depending on the cause, use one of the following workarounds.
Add a backup toolbox or rebuild the model
Currently, there is no way to recover corrupted, or outdated toolboxes unless a backup is available. Refer to ArcGIS Pro: Use a custom geoprocessing tool for instructions on adding an available backup toolbox in ArcGIS Pro.
If no backups are available, the only option is to rebuild the toolbox using the same parameters with ModelBuilder or Python in ArcGIS Pro. Refer to ArcGIS Pro: Use ModelBuilder for more information.
Ensure that the tool is available for use in ArcGIS Pro
Ensure that the tool is compatible with the ArcGIS Pro version
The following tools can be used to determine if the toolbox is compatible with the version of ArcGIS Pro used and save it to be compatible with any version of ArcGIS Pro or ArcMap:
Refer to ArcGIS Pro: Save toolbox to previous version for more information.
Article ID: 000028245
Get help from ArcGIS experts
Start chatting now
