PROBLEM
ArcGIS Pro crashes on start-up after upgrading ArcGIS Pro and uninstalling the Deep Learning Framework
Last Published: March 24, 2021
ArcGIS Pro crashes after installing the Deep Learning Framework, upgrading ArcGIS Pro, and uninstalling the Deep Learning Framework using the Windows Installer (.msi).
Cause
Uninstalling the Deep Learning Framework using the Windows Installer (.msi) removes components needed to run ArcGIS Pro.
Solution or Workaround
Should this issue occur, either repair the software using the Repair option in the ArcGIS Pro .msi installer, as shown in the image below, or simply uninstall and reinstall ArcGIS Pro.
ArcGIS Pro installer
Article ID: 000025264
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
