PROBLEM
After upgrading from ArcGIS Pro 3.4 to 3.5, while ArcGIS Pro AI Assistant 3.4 (Beta) remains installed, creating or opening a project may cause ArcGIS Pro to crash.
The ArcGIS Pro AI Assistant 3.4 (Beta) was designed for use with ArcGIS Pro 3.4 and may not function correctly with newer versions of ArcGIS Pro, leading to application instability after an upgrade. ArcGIS Pro AI Assistant 3.4 (Beta) is not compatible with ArcGIS Pro 3.5. The presence of the beta assistant interferes with the normal operation of ArcGIS Pro, resulting in crashes when projects are opened or created after an upgrade.
To resolve this issue, follow these steps:
Article ID: 000036172
Get help from ArcGIS experts
Start chatting now
