PROBLEM
ArcGIS Monitor 2024.1.1 crashes immediately after startup
First Published: May 30, 2025
Last Published: July 17, 2025
When attempting to start ArcGIS Monitor 2024.1.1, the service initiates and briefly displays a "Running" status in the Windows Services console. However, within a few seconds, the status reverts to a blank state, indicating the service has stopped unexpectedly. ArcGIS Monitor displays no error messages, and the application fails to remain active.
Cause
The CONFIG_STORE_PATH variable in the .env file has the wrong ArcGIS Monitor account, pointing to the default 'arcgis' user instead of the intended domain account due to a failed installation.
Solution or Workaround
The AppData folder is hidden by default. Refer to the Show hidden files drop-down in Microsoft Support: Common File Explorer options for instructions to display hidden folders.
  1. On the ArcGIS Monitor machine, in File Explorer, navigate to the .env file, which by default is located in:
C:\Users\<ArcGIS Monitor Domain Account>\AppData\Local\ESRI\ArcGISMonitor\config-store-server
  1. Right-click the .env file and open the file in a text editor, for example, Notepad.
  2. In the text editor, navigate to the CONFIG_STORE_PATH variable.
  3. Edit the domain account in the file path to include the user's domain account. An example of the edited file path is:
  1. Save the .env file and close the text editor.
Article ID: 000036265
Software:
  • ArcGIS Monitor Administrator
  • ArcGIS Monitor Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
