PROBLEM
To use ArcGIS Maps for Office with the Enterprise stack, it is required that certain web resources are installed on the Portal for ArcGIS directory. In a typical deployment, when the installer is run, the resources are extracted to this location:
Files\ArcGIS\Portal\framework\webapps\rootapp\resources\arcgismapsforoffice\5.0
After these resources are installed, the location should contain the following subfolders:
Files\ArcGIS\Portal\framework\webapps\rootapp\resources\arcgismapsforoffice\5.0\office\<Build #>
When using Portal for ArcGIS 10.7 for Linux, the installer cannot locate this file path.
Files/ArcGIS/Portal/framework/webapps/rootapp/resources/arcgismapsforoffice/5.0
Files/ArcGIS/Portal/framework/webapps/rootapp/resources/arcgismapsforoffice/5.0/office/<Build #>
Article ID: 000020621
Get help from ArcGIS experts
Start chatting now
