PROBLEM
Append geoprocessing tool fails with error 000262 in ArcGIS Pro
First Published: April 10, 2026
Last Published: September 24, 2026
In ArcGIS Pro, running the Append geoprocessing tool with a shapefile as the target dataset fails and the error described below is returned:
Error:
000262: Target <feature class name> is read only.
Failed to execute (Append).
Cause
The target dataset is read-only or locked, preventing tools like Append, Merge, or Edit from modifying it.
Solution or Workaround
Remove the read-only property of the target dataset
  1. Open Windows File Explorer.
  2. Locate the target dataset, right-click the file, and select Properties. In this example, the target dataset is a shapefile.
  3. Uncheck the Read-only box and click Apply.
The Properties window of the shapefile
  1. In ArcGIS Pro, to ensure there are no further issues, consider:
    • Removing any existing joins if appending to a shapefile.
    • Removing any file locks on the input dataset in the containing folder. Use the Compact tool if necessary.
    • Refreshing the Catalog pane or restarting ArcGIS Pro to release temporary locks.
Article ID: 000041218
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
