PROBLEM
Note: This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Text annotation in ArcMap is not rotating when the Rotate Data Frame Tool is used. This can happen with both Geodatabase annotation and with annotation stored in the map.
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Some ArcGIS annotation does not rotate with the data frame. This includes some annotation created in earlier versions of ArcGIS. This means that when the Data Frame Rotate tool is used, the annotation does not rotate along with the data.
In ArcGIS version 8.3 and later, run a VBA code to modify the annotation so it rotates when the data frame is rotated.
Note: The reverse is also possible: to make annotation that rotates with the data frame, remain stationary.
Follow the steps below.
Option Explicit Const ROTATE_WITH_TRANSFORM = True Public Sub SetAnnotationRotateFlag_Geodatabase() ' 1. Start Editing ' 2. Select Geodatabase annotation features using Edit tool ' 3. Change Const value above to either True or False (True = rotate text when dataframe rotates) ' 4. Run this code ' 5. Stop Editing, Save Edits Dim pEditor As IEditor Dim pID As New UID Dim pEnumFeature As IEnumFeature Dim pFeature As IFeature Dim Count As Long Dim pActiveView As IActiveView pID = "esriCore.Editor" Set pEditor = Application.FindExtensionByCLSID(pID) pEditor.StartOperation Set pEnumFeature = pEditor.EditSelection pEnumFeature.Reset Dim pElement As IElement Dim pAnnoF As IAnnotationFeature Dim pTextElement As ITextElement Dim theAnnoString As String Dim stringToReplace As String Dim replacementString As String Dim pTextSym As ITextSymbol Dim pSymRot As ISymbolRotation Set pFeature = pEnumFeature.Next Do Until pFeature Is Nothing Set pAnnoF = pFeature Set pElement = pAnnoF.Annotation 'only work with text elements If TypeOf pElement Is ITextElement Then Set pTextElement = pElement Set pTextSym = pTextElement.Symbol Set pSymRot = pTextSym pSymRot.RotateWithTransform = ROTATE_WITH_TRANSFORM pTextElement.Symbol = pTextSym pAnnoF.Annotation = pElement Set pFeature = pAnnoF pFeature.Store End If Set pFeature = pEnumFeature.Next Loop pEditor.StopOperation "Set Rotate With Transform" pEditor.Display.Invalidate Nothing, True, esriAllScreenCaches End Sub Public Sub RotateWithTransform_Map() ' 1. Select Map annotation using the Select Elements tool ' 2. Change Const value above to either True or False (True = rotate text when dataframe rotates) ' 3. Run this code ' 4. Save your .mxd to save changes Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Dim pGraphicsContSelect As IGraphicsContainerSelect If pMxDoc.ActiveView Is pMxDoc.PageLayout Then Set pGraphicsContSelect = pMxDoc.PageLayout Else Set pGraphicsContSelect = pMxDoc.FocusMap End If Dim pElement As IElement Dim Count As Long Count = pGraphicsContSelect.ElementSelectionCount - 1 Dim i As Long For i = 0 To Count Set pElement = pGraphicsContSelect.SelectedElement(i) If TypeOf pElement Is ITextElement Then Dim pTextElement As ITextElement Dim pTextSymbol As ITextSymbol Dim pSymbolRotation As ISymbolRotation Set pTextElement = pElement Set pSymbolRotation = pTextElement.Symbol pSymbolRotation.RotateWithTransform = ROTATE_WITH_TRANSFORM pTextElement.Symbol = pSymbolRotation End If Next i pMxDoc.ActiveView.Refresh End Sub
Article ID:000006191
Get help from ArcGIS experts
Download the Esri Support App
