PROBLEM
An Image service can be created using the Route Server data but not a Route service
The Route Server extension for ArcIMS has been installed as well as a supported release of Route Server SDC-format data. Using the sample configuration file that is installed with the data; for example, usa.axl, users are able to create an Image service. However, when users attempt to create a Route service using the same configuration file, the following error is returned:
"Error When trying to administer Service"
Cause
The Route Server version installed may be incorrect.
Solution or Workaround
There are two CDs included in the ArcIMS Route Server box, one labeled 'Route Server 1.0' and one labeled 'Route Server 1.0 for ArcIMS 4'. Use the latter for ArcIMS 4.0 and ArcIMS 4.0.1.
If installing from a network location, check the date of the installation executable (AIMSRouteServerSetup.exe):
1. The file compatible with ArcIMS 3.1 is dated Nov. 13, 2001.
2. The file compatible with ArcIMS 4.0 and ArcIMS 4.0.1 is dated April 1, 2002.
Article ID:000006738
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
