PROBLEM
An HTTP line is larger than 4096 bytes in GeoEvent Server logs
Last Published: May 21, 2021
When using a spatiotemporal big data store with ArcGIS GeoEvent Server, the ArcGIS GeoEvent Server machine may suffer from performance issues, displaying the following error message in the log files:
Error:
Error: {"error":{"root_cause":[{"type":"too_long_frame_exception","reason":"An HTTP line is larger than 4096 bytes."}]
This error message may fill up the log files.
Cause
ArcGIS GeoEvent Server attempts to make a request of 4096 bytes or higher to the Elasticsearch associated with the spatiotemporal big data store. This is not allowed by Elasticsearch, preventing the request and returning the error message.
Solution or Workaround
Perform the workaround below to resolve the issue.
The following workaround must be performed on all spatiotemporal big data store machines deployed in the ArcGIS Enterprise environment.
  1. Log in to the spatiotemporal big data store machine, and stop the ArcGIS Data Store service.
  2. Navigate to the following directory:
C:\Program Files\ArcGIS\DataStore\framework\runtime\elasticsearch_<latest_version_number>\config\
  1. Open the elasticsearch.yml file with a text editor software.
  2. Search for the following line:
#http.port: 9220
  1. Add the following line below the line in Step 4, and save the .yml file:
#http.max_initial_line_length: 10kb
The value for '#http.max_initial_line_length' may need to be set to a higher value, depending on the size of the request made by ArcGIS GeoEvent Server.
  1. Restart the ArcGIS Data Store service.
Article ID: 000025323
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
