PROBLEM
The Servlet Connector may use one of two methods for processing: InputStream (default), or getParameter. The method to use depends upon the locale, web server, and Servlet Engine. If one method doesn't work, the other method might.
The method may be changed by entering the useCustomProcessing property to the Esrimap_prop file: useCustomProcessing=true (uses InputStream method)
useCustomProcessing=false (uses getParameter method)
See the test matrix below for scenarios in which these methods work and do not work.
Test matrix for multi-byte characters in ArcXML request
IS: InputStream
GP: getParameter
Encoding refers to the value of encoding in arcXML.js and htm pages.
Locale Web server–Servlet engine configuration
(Encoding) IIS-Jrun IIS-ServletExec IPlanet Apache/Tomcat
English IS (ok) IS (ok) IS (ok) IS (ok)
(default UTF-8) GP (ok) GP (ok) GP (ok) GP (ok)
Trad Chinese IS (ok) IS (ok) IS (ok) IS (ok)
(Big5) GP (not ok) GP (not ok) GP (ok) GP (not ok)
Simplified Chinese IS (ok) IS (ok) IS (ok) IS (ok)
(GB2312) GP (not ok) GP (not ok) GP (ok) GP (not ok)
Japanese IS (ok) IS (ok) IS (ok) IS (ok)
(shift_jis) GP (not ok) GP (not ok) GP (ok) GP (not ok)
Article ID:000002652
Get help from ArcGIS experts
Download the Esri Support App
