PROBLEM
An ArcGIS Survey123 nested group or repeat with a grid layout does not span the full width of the survey
First Published: December 6, 2023
Last Published: January 24, 2024
In ArcGIS Survey123, when creating a survey with nested group or repeat questions in a grid layout, the nested group or repeat does not span the full width of the survey.
The image below shows a nested repeat in the survey with a dynamic grid layout in ArcGIS Survey123 Connect. The nested repeat is displayed as compressed to one side of the screen, leaving an empty space in the survey.
The nested repeat not spanning the full width of the survey and leaving a blank space
Cause
This issue occurs when the number of columns for the nested group or repeat to span within its parent group is not specified in the appearance column of the survey’s XLSForm. By default, questions within a group only occupy one column of the grid. When creating nested groups or repeats in a grid layout, the number of columns of the parent group must be specified, along with the number of columns each nested group or repeat is to span within its parent group.
The appearance column of the nested repeat left empty in the XLSForm
Solution or Workaround
In ArcGIS Survey123 Connect, use the width parameter to specify the number of columns for the nested group or repeat to span in the appearance column of the survey’s XLSForm.
  1. Open the survey’s XLSForm in ArcGIS Survey123 Connect.
  2. In the appearance column for the nested begin repeat or begin group question type, type the formula provided below. Replace <columns> with the number of columns in the parent group, and <span> with the number of columns from the parent group the nested group or repeat is to span.
w<columns>:<span>
The code block below shows the full working formula. In this example, the formula is inserted into the appearance column for the nested begin repeat question type, and the nested repeat is to span three out of three columns from the parent group.
w3:3
The appearance column of the nested repeat populated with the formula
  1. Save the XLSForm, and in ArcGIS Survey123 Connect, click Publish survey The Publish survey icon to publish the survey.
The image below shows the nested repeat spanning the full width of the survey.
The nested repeat spanning the full width of the survey
Article ID: 000031625
Software:
  • ArcGIS Survey123 Field App iOS
  • ArcGIS Survey123 Field App Android
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
