PROBLEM
All records for topology attributes have values of zero
Solution or Workaround
All records for the arc topology attributes, FNODE, TONODE, LPOLY and RPOLY appear with values of zero.
Cause
You are running the SHAPEARC command and the shapefile does not have the proper node information, or you have edited a coverage and the node information has errors or duplications.
Solution
1. Run the RENODE command on the coverage to reassign each node a unique identifier.
2. Run the CLEAN or BUILD commands to rebuild ARC/LINE topology.
The LPOLY and RPOLY attributes can still have values of zero as described in the online help under the BUILD command.
Article ID:000001708
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
