PROBLEM
All controls for creating indexes in ArcCatalog are grayed out
Cannot create an index for a data field because the controls for creating indexes are grayed out.
Cause
To create an attribute or a spatial index, a single ArcCatalog session must be the only application accessing the data.
Solution or Workaround
  • If the data is being viewed in ArcMap, remove, then re-open the properties dialog box in ArcCatalog to create the indexes.
  • If the commands remain grayed out, it is very likely someone else is accessing the data from a different computer.
Article ID:000002983
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
